My engine has only been in and running for around 350 miles. Tonight the car battery was dead, and I noticed that last time I started it it also
seemed sluggish turning over.
I've connected a meter to the battery, and the voltage is around 11.5 with the engine off, and 11.5 with the engine running.
I'm not sure whether my alternator is knackered, or wired in incorrectly. I bought my donor mondeo as a runner, and it had a flat battery, but
I presumed this was because it'd been stood for a while.
The alternator had two wires - one big beefy red one, and one tiny one, which I think was for the instrument cluster. I've connected the beefy
one to the starter solinoid - as good as straight to the battery. I've left the smaller one disconnected. Does the smaller one perform some
other function, without which the altenator might have burned out, or is this just a simple case of a worn out alternator (the mondeo had 105k miles
on it)
Gary
The smaller one is for the ignition light
an alternator needs a feed to start the alternator charging thats what the small terminal does
As previously said the small wire needs to go to the ignition lamp with other side of lamp going to 12volt ignition controlled supply.This wire is used to start the alternator to charging.Without this wire connected via a lamp that is going to 12 volt your alternator will not work.
So to answer your question - nope your alternator is not working
Best of luck fixing it
Ah - I thought the lamp wire just lit the lamp - I'll wire it up tonight!
Gary
Gary
result - I now have 14.3 volts on the battery with the engine running!
Cheers!
Gary
turns out this wasn't as straightforward as I thought :-( A week or so after fixing this problem, I was back to square one - no voltate
increase when the engine is running, and the dashboard light always illuminated.
The wiring hadn't changed, so I fitted a replacement alternator. This worked for a short time, but now, once again, nothing.
I think the wiring is somehow burning out the alternators. The dashboard light no longer goes out. I've just borrowed an ammeter from a friend
so I'll measure whether there's any output tonight.
Gary
I would check the earth path all the way from the alternator to the battery. Some alternators have plastic bushes on the pivot and at the adjuster so
you may need to add another earth path to the engine block or chassis.
You are probably blowing up the rectifier somehow, it can be quite cheap to get these fixed if you have a good old fashioned auto electrician around,
one who knows which end to pick up a soldering iron!
Also worth checking all the wiring for loose or dirty connections including the lamp holder for the ignition light, also check that this is wired the
same way as it was in the donor!
Where are you getting your alternators? If they are all ex scrappy they could be already damaged for example if the car was arc welded without the
alternator being disconnected!
Good Luck
Caber
I trust the alternator bracket - all metallic and clean, but I'll check the earth path.
The lamp wiring is a problem - the car is mid engine'd using a modified FWD escort loom, and I have a mondeo engine sub-loom grafted into that.
The mondeo subloom has a 42 way connector, which I've reduced down to 9 or 10 wires by eliminating things like AC clutch, rad fan, and other
items that don't exist on the car. I have a niggling feeling it's something on this connector I might have missed.
The first alternator was an unknown from a breaker, and the last one is from eBay, so none were a known quantity really, apart from the fact that they
delivered a higher voltage for at least the first 30 or so minutes of running.
Thanks for the suggestions - I'll report back!
Gary
Isnt there an issue with blacktop alternator charging being controlled by the Ford ECU in the original installation. Best to use the usual suspects
like suzuki/nissan/rascal or an older ford type if space is not an issue.
[Edited on 5/7/06 by Dusty]
I wasn't aware of that. I'm running the standard ECU at the moment, but was planning to fit an MS at some point in the future.
I'll have a search around google... maybe the alternators are fine, and it's just the ECU doesn't have the right information so has
told the alternator to stop charging <sound of straws being clutched>
Gary
