I can't find anywhere that sells these little buggers
wiring connector
They are 20mm long 3mm wide.
As fas as I can tell pretty much all modern cars use these as standard within the wiring loom, but none of my local automotive (boy-racer) shops sell
them.
Alex
premier wiring will sell them to you (and the plastic blocks they go in)
Thanks Mike, spot on!
polevolt sell them, as do vehicle wiring products
vehicle wiring products will definately have something to fit..
I think I may have some of these, bought from VWP - is you need a couple, then I put some in an envelope & send - will save you on the
extortianate P/P VWP charge
