While thinking of things to look at during the winter period, one of the things that doesn't quite sit right is the Sierra key hanging out of the
ignition.
I have push button start and would love to bypass the Sierra key. Has anyone put in a keyless system using maybe a keypad or proximity system, dongle
or whatever?
have a word with brooky. he's got a system from a bike and i have to say, i like it!
looks cool, he jumps in, puts his helmet on, presses start and he's off........
no faff!
and impossible (within reason) to nick cause if anyone else jumps in it won't start
I've got a cheapo bike alarm from ebay(£30),to use in the same way, has 2 immobiliser circuits,andalso has remote start!!!!
Ray
don't forget to remove the steering lock though,
jump in, start engine, drive off, into a wall, not a good look!
mike
Hmmm, good point - is it easy enough to take out the whole barrel and lock?
Ray - have you got that operational?
I always thought you could use a credit card type starter with a printed circuit push it all the way in and it activates the starter halfway in and
it runs.
The Key (excuse the pun) would be to set up the layered card so that the contacts fall just right.
(goofy idea...just a thought)
My car has an Fia switch with an immobiliser coil around it. I have embedded a transponder in clear resin along with the fia key.
This means that the key is sva proof on the radius, plus a normal fia key will not allow my car to start.
I have a lift up aircraft switch for the starter.
Originally posted by dl_peabody
I always thought you could use a credit card type starter with a printed circuit push it all the way in and it activates the starter halfway in and it runs.
yes had it running with the loom just plugged in as it would have been on the bike.
basically press one button on the fob,disarms alarm+immobiliser, and turns ignition lights on(like run position on standard ignition switch), then use
second button on the fob(for remote start) or a dash mounted pushbutton.
only thing i did was wire an extr relay in connected to the neutral light switch, so i can;t remote start with it left in gear.
Ray
try findlay,he was mking some to sell some time ago
Alot of chavs seem to know about keyless ign. They screwdriver the barrel and join some wires together. Hey presto no keys
Raywards idea sounds good. Is it easy to do??
Well, i have a complete computerized system build onto my locost.
the ignition barrel is there because of the steering lock.
I wanted to know is it obliagotory to have it?
i have made a smartcard system sow introduce my smartcard and then the plane is booting and you can start with the push of a button (like mercedes,
sow you toggle the start sequence not the start relay) if starting takes more than 7sec error messages start popping up
etc. etc.. will make some pics when its all mounted etc..
Tks
if you can wire a locost, then fitting this alarm in sholud be no problem.
the one i bought is very similar to the one in the link below
click
ety Link
Ray
If anyones interested in a keypad immobiliser, ive just finished the final working prototype and tested it in my FIAT Bravo (ill tell you the
electrics in fiats are more confusing than my homebrew wiring loom for the kit) The machine works and immobilised the starter relay. It can be used to
immoblise any relay on the car.
At the moment it works with a keyed ignition switch but it would be a very very simple conversion to keyless.
Starting, with the key out and the circuit immobilised with led showing red, you type in the preset 4 digit code. On each button press the led lights
up amber. Once the correct code has been input the led will turn to green and the car can be started. When you turn the engine off and turn the key to
its off position or remove it, the immobiliser will wait 10 seconds then check the key switch is still off and immobilise the circuit. The 10 second
wait incase you stall and mean to turn the engine on again.
There is also a valet function where you can make sure it doesnt immobilise a circuit when you get out.
At the moment im looking for someone whos got their car to rolling chassis with a working engine that can test the immobiliser on a road for short
distances. If anyone can help or wishes to dive in straight away and get one then let me know.
Lastly and mainly if there are any ideas that people have to enhance the project then also tell me...
cheers
findlay
how about a shocking coil possibly from one oh those games or rc tanks that zaps you if you get the code wrong twice? Do it a third time and it gives
you a shock off an ignition coil!
A it helps you to remember the code
B it will sort out anyone who tries it on!
PS also link coil to windscreen wipers, reduces the instances of parking tickets!
Caber
where is the warning if someone is in the car and don't pushes in the right code???
(claxon relais??) also an switch in the seat would be beautifull!!
also i think a small display (with blue backlight) would do some nice details and info about the actual status of the code and the program in the
microcontroller.
i have some nice displays if you want..
Tks
All you need is an RFID chip surgically planted in the cheek of your bum. Then put the transponder under or in the seat or on the sidewall. Every time
you sit in the car, you can start it but no one else can.
Do remember to disable the steering lock as without the key it will lock the steering wheel.
The biggest problem is purely around not having a key, and locking up the steering.
Having said that, the key does provide the physical anti theft device (Steering lock).
The imobilisation and starting is relatively straightforward.
