I could do with getting them tomorrow so I can crack on with a few things.
One is a right angle connection off a bike battery and the other uses an 8mm bolt to hold it in place on the starter relay.
battery1
battery2
Premier Wiring does a range of battery terminal connectors.
autosparks are worth a shot....
just carefully unpick the ones you have Andy. I did this with no probs on my last build
Might be a good idea to solder the used ones back on though - they might not grip reliably when second hand
