Hi,
Fired up XE for the first time today!!
And it works...
Does anyone know which wire from the engine loom is the feed to the rev counter??
Also will it work with my rev counter, my gauge used the Neg - off the coil to feed it.
Green
Yep - green, some of the other wires vary between the looms over the years - but that stays the same....
Not sure about the second bit of the question though.
Chris
Well it worked!!!
Thanks for your help.
Russ
