the alt needs a bulb to charge.. but whats the best way of doing it if you want to use a led and not a bulb ?
Wire a bulb in, under the dash?
Mike
Hmm I'm not sure the LED will normally in this application as the wire that feds the light also supplies the start current (proper name I forget)
to the alternator. Once the alt is upto speed and is producing a higher voltage than the battery the current is stopped and hence the light goes out.
Question is - does an LED flow sufficient current to charge the alternator coils, probably not...
You could wire it in parallel but not directly through the LED.
[Edited on 21/3/07 by Mr Whippy]
It depends on the engine. Some setups are pretty tolerant of bulb resistances. The ST1100 meanwhile was a little git trying to get the right lamp
resistance. Anything over a few ohms and the excitor circuit to the alternator stopped working preventing any output!!!
In the end I removed the lamp altogether!!!
[edit]
ie I had shorted it to ground rather than leaving the connection open.
[Edited on 21/3/07 by BenB]
Put a paralell resistor over the diod and diod resistor, to create som "starting current" for the alternator. I use about 100 ohm in paralell, works OK on my cross flow.
bear in mind the the LED will not show an over charging condition whereas a bulb will (unless you fit another LED the other way round).
Over charge???? if the bulb is 12volt bulb you will need 24VOLTS to lit it up correctly!!
24 - 12 = 12 volts!!
When applying 24volts to the car system you are already smoking and allot of stuff burns out..
Tks
ta for the infowill try 100ohm and see how it goes
And yes, as you say, other parts of the electrical system will start smoking but unless you have lights turned on, it will only be the ignition that will suffer..... but ofcourse you would have turned off the engine since you saw the lamp come on![]()
Remember that the bulb only sees 6 volts when the system sees 18!
and how do you know that its overvoltage instead of just a dynamo wich is broken??
CORRECTION. Having thought about it, the lamp or any LED will never light up for overcharging since there will be no voltage difference between
alternator and battery.
Sorry for the misinformation but noone else spotted it
