what is the best way to fit savage switches (brushed ali) i want them quite flush
I used a stepped drill, worked perfectly
step drill its like a christmas tree
youll find that you can unscrew the switch completely and fit them almost perfectly flush
as above - if you take the collars apart completely it will be a little clearer, then use a step drill or hole saw for correct size- 22mm I
think???
