As the title says really, for the main feed from alternator to battery.....
James
16mm wire.
got mine from VWP
near bottom of this page:
http://www.vehicle-wiring-products.co.uk/VWPweb2000/cables/cables.html
[Edited on 16/4/07 by ned]
Ta.
James
Any good motor factors should have a coil on the shelf.
get some from an old loom
I used two parallel runs of 6 mm2 calbe -this is the largest diameter that will fit the lucas type plug with the side tags. (that is good for 100A -
the alternator is rated at 65 A so more than ample).
16 mmm2 !!!
Originally posted by ned
16mm wire.
got mine from VWP
