Reverse switch
MB - 2/8/03 at 05:30 PM
I'm working on the electrics for my car (SVA by end of year I hope!) and am having problems with the reverse switch in my Mk2 Escort gear box.
Problem is, it doesn't appear to reach quite far enough. It does work if I put a screwdriver in the gear lever mechanism and give it a little push or really push hard on the gear lever.
Is my switch just worn, or is there any way of adjusting it?
chrisg - 2/8/03 at 06:30 PM
Is it screwed all the way in?
I don't think they're adjustable, it may be buggered, get another one they're cheap.
Chris
Had a thought, the bit that contacts the switch on the gear lever could be worn.
[Edited on 2/8/03 by chrisg]
bob - 2/8/03 at 07:29 PM
On a type nine 5 speed box there is a little black plastic saddle that sits over the selector rod,the gear stick fits over this.
I know my selector wouldnt work without this,not sure if it affects the reverse light switch though.
Or
maybe you have wrong switch,might not have enough reach.
bob - 2/8/03 at 07:30 PM
Just seen its a MK2 escy box,should have had my glasses on,Doh!!
theconrodkid - 2/8/03 at 08:05 PM
dont need reverse lights for sva and its extra wire/weight
