hi can anyone tell me what kind of coil this is? I need to figure out where to plug my tacho into.
thanks guys.
sorry about the size of the pic!!!
Does it have any manafacturer parts numbers stampted on it?
That and google often brings up something
it says BAE504 on it. cant find much on google
It will just need to pick up the pulse same as on any other coil won't it? The - terminal will give you that.
there are 4 wires going into it tho and I cant see a - terminal.
its a bestek leccy ignition.
Looking up that code I get
http://www.cistrading.com/page3/page14/3.htm
It shows up quite a few cars that use that same coil. You could try looking at the Haynes manual for one of those cars....
Cheers.
thanks Ill head down to halfords now and look through all the haynes manuals.
maybe a better question is where does the - terminal on a coil normally connect to?
The - terminal normally connects to your distributor
ok cool, I have an electronic dizzy and besek amplifier so Ill see what I trace around.
