zx9r wiring dilema part two
roadrunner - 3/2/08 at 04:34 PM
Now that i have sorted my headlamp problem i still have no spark , i have tested the voltage at various places across the loom and all seems ok, i even have voltage at both wires leading into each coil stick, has anyone any ideas, am i supposed to have a voltage at both wires leading into the coils, or does it mean something else is wrong.
Thanks Brad.
Mark G - 3/2/08 at 04:42 PM
have you remembered to earth your engine to the chassis?
roadrunner - 3/2/08 at 04:58 PM
Thought of that, and yes it seems to be a good earth.
cossiebri - 3/2/08 at 05:37 PM
Brad try this, with the ign on disconnect the smaller plug off the ecu (To coil packs)then reconnect and try and start. This is what i had to do when i had the same symptoms as your descibing
bigrich - 3/2/08 at 05:46 PM
if the wires are attached to the coils then both sides will show voltage but if the wires are disconnected from the coils and are both still live you have a problem.
It sounds as though the ecu is not switching the coils on and off which could be a anti hot wire(grey wire 100ohm fault) or poss a crank sensor fault so the engine does;nt know its spinning over
dan__wright - 3/2/08 at 07:13 PM
i had this problem on my zx10, everything come on but no spark, it was to do with the starter lockout circuit, check everything on that circuit.
was v strange as injectors fired but no spark
roadrunner - 3/2/08 at 07:45 PM
Tried this thanks Bri, but still no spark.
roadrunner - 3/2/08 at 07:49 PM
I tested this Rich, i disconnected the coils and only got a voltage through one of the wires, i also checked the grey wire with the 100ohm resistor and everything seems fine and dandy, as for the crank sensor there is'nt one, did you mean the cam sensor.
roadrunner - 3/2/08 at 07:50 PM
What do you mean by the starter lockout circuit Dan.
Another thing, does the passing switch need to be earthed, as mine is not.
bigrich - 4/2/08 at 10:50 AM
I did mean the crank sensor, it may be listed as inductive pulse pick-up and if its colour coded like my zx10r then its a red/black wire and a black wire which should be fitted inside one of the crankshaft end covers
