Have fitted an LED happy relay and indicators now flashing peoperly. However - it doesn't make a noise.....
Is there a requirement for audible warning ??
Simon
yep. has to make a noise. add a buzzer somewhere and should be fine
Mine makes no noise...It just needs a green arrow to flash on the dash display.
So if you have a light flashing with the correct symbol you do not need a buzzer>>>
Paul
Paul
With my last 7, even though I had the correct green lights, I ended up fitting a buzzer after a while because without something audible, I kept leaving the indicators on by mistake.
WRONG!
I had an MOT fail over this with the land rover.... and looking in the SVA manual it says:
Note: The "tell-tale" may be audible or visual. It is not required if one or more indicators on each side of the vehicle can be seen by the driver from the driver's seat
Note: The "tell-tale" device must be in the form of a flashing light, which may be the same lamp as the direction indicator "tell-tale"
Passed SVA today with silent indicators. Guess it may be a different question come MOT time but SVA man seemed happy enough !
Simon
