VDO Speedo + Type 9 gearbox.
Sebastian - 19/10/08 at 11:55 AM
Hi,
Who knows what you have to do when you have a electric VDO speedo in combination with a type 9 gearbox, which obviously uses a mechanical pulse.
Is there a special part for it to get the pulse converted from mechanical to electrical?
Thanx.
big_wasa - 19/10/08 at 12:22 PM
An adapter from burtons then a standard ford sensor.
ps its a hall efect sensor, make sure your speedo will take the signal and that you have room to get it in the tunnell.
I am using a telemetrix speedo and it seems to work a treat, very smooth and no magnets to loose. (mt75 already has the sensor built in)
big_wasa - 19/10/08 at 12:27 PM
Adapter £15
Sensor £30 new or get a second hand one
big_wasa - 19/10/08 at 12:30 PM
see
link
Sebastian - 19/10/08 at 06:36 PM
Thanks big-wasa.
