Relay attachment
shortcircuit - 15/7/20 at 06:13 PM
Is there a requirement for relays to be located within a purpose type enclosure or can they be securely attached to the harness? [Flasher, fan and reverse light relay- out of cores for reverse]
britishtrident - 15/7/20 at 07:16 PM
You can get relay sockets with built in brackets also ones that clip together and with built fuse holders. Don't forget you can also standard 4 pin relays that have a fuse holder as part of the relay
[Edited on 15/7/20 by britishtrident]
shortcircuit - 15/7/20 at 07:20 PM
Thanks for the info. I was aware of multiple sockets but being a bit of a cheapskate was just going to tie to loom. Have messaged a supplier for a unit concerning the size of relay it can take as the flasher is about 28mm. Will wait and see.
