carpmart
| posted on 11/1/09 at 01:10 PM |
Odessey PC545 battery, is it man enough for a pinto install?
Hi Chaps
As per the question really, will this battery be man enough to start my pinto powered fury? Anyone got one on their pinto engine install?
I run quite a low compression engine as its turbo charged and a standard pinto starter. I've got the battery 'in stock' so its this
or the standard car battery which I have on there! I need to change the connectors else I would just try it!
What's the consensus, standard or the Odessey?
Thanks!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
iiyama
| posted on 11/1/09 at 01:56 PM |
495 cranking amps for 10 secs. How much power do you need????
If its broke, fix it. If it aint broke, take it apart and find out how it works!
carpmart
| posted on 11/1/09 at 02:01 PM |
Yep thanks iiyama, I'm aware of the figures, just wanted real world experience with this small a battery. Have you used one yourself in a CEC
application? Will my alternator be too big for it as well?
'94 MX5 MK1, 1.8
Worzey
| posted on 11/1/09 at 02:49 PM |
I'm using one in a 20v 4AGE without any problems.
Caterham R400
procomp
| posted on 11/1/09 at 03:26 PM |
Hi
Personally i only ever use the Odyssey PC625 these days. This has worked well with quite a bit of abuse thrown at it. Ie starting and stopping of the
race engines which can sometimes be a PITA to start when on 40's etc. Would not go back to using the red top type ones again they are too
fragile compared to the Odyssey ones.
Cheers Matt
iiyama
| posted on 11/1/09 at 03:37 PM |
Battery is rated @ 14ah which most car batteries are, so your altenator will be fine. Whats the cranking amps of the OEM battery? Will be a lot less
then the odessey I bet.
Regarding using one, yes I have one in my car although its turning a Busa motor. Could probably have gone down a size for my uses.
graememk
| posted on 11/1/09 at 04:23 PM |
545 starts my nissan powered cec indy, not a had a prob all year with it
carpmart
| posted on 11/1/09 at 04:52 PM |
Thanks for the replies chaps! It seems as though it will be fine so I will stick it in the car!
'94 MX5 MK1, 1.8
Roman
| posted on 12/1/09 at 03:53 PM |
Where's the cheapest place for these?
Roman
| posted on 26/1/09 at 03:56 PM |
Anyone?
