Author: Subject: Extending front indicators
bonerp
posted on 31/1/04 at 05:53 PM Reply With Quote
Hi all,
What have people used to extend their front indicators for SVA?
I was going to use conduit but the thread and nut is 25mm and don't fancy having great holes in the nose as my indicators are only 8mm bolts.
Paul
TPG
posted on 31/1/04 at 06:41 PM Reply With Quote
I used 20x3 flat bar.Drilled a hole in each end to suit bolt sizes.Rounded the ends off and then bent the ends 90 degrees.Painted them black.No bother at the sva in jan of this year.
Julian B
posted on 2/2/04 at 09:33 AM Reply With Quote
Lolocot (http://www.lolocost.com) do these
The are only £24 including postage and are e-marked so sva complient. This is what they looked like on the front of my old car.
zetec
posted on 4/2/04 at 08:49 AM Reply With Quote
I used a legth of 22mm copper tube. Buy some solder end stops, drill them and glue in the mounting bolts or nuts you want to use and then solder or glue them onto the length of tube, cheap and easy and don't look too "just for SVA".
