jonti
| posted on 19/2/04 at 07:09 PM |
Electronic Speedo Wiring
Chaps
I have aquired an AST electronic speedo with no instructions..
On the back it has four terminals arranged thus:-
L G
Now '+' and ' - ' are you would think straightforward and the L is defintootly the backlight.
I have with it a transducer see pikkie which has only two wires on it. a black one and a white one. I've tried every combo I can think of but I
can't make the beggar work. I strapped four magnets onto a sanding disk to simulate the prop
Any ideas as to how this might be wired or does anyone know please ?
Your thoughts, ideas, ridicule all gratefully recieved
J.J
[Edited on 19/2/04 by jonti]
OFROK
stephen_gusterson
| posted on 19/2/04 at 08:25 PM |
The screen will almost certainly be ground / earth connection.
Have you tried asking the mfr?
Are you sure its the right sender - it looks like a typical industrial sensor to me. - any markings or ID on it?
lots of those sensors are not magnetic, and sense a metal object by capacitance, or the presence of a moving metal gear or some such.
if there is a screen, with a wire in it and a further wire, id guess screen = earth, screened wire = signal, other wire = power.
dont blame me if it blows up tho.....check all else before taking a risk
atb
steve
stephen_gusterson
| posted on 19/2/04 at 08:27 PM |
another take is
L = lights
g = ground
+ = power
- ?%#^^$??? could be signal?
atb
steve
jonti
| posted on 19/2/04 at 09:42 PM |
Thanks chaps for suggestions
Both wires are just wires, neither screened
I'd already checked the continuity and theres nothing to the body and about 400ohms across the two wires, as Syd says, indicating bog standard
transducer of some sort either field or capacitance sensitive.
I've no reason to doubt its the right sender, though it may not be I suppose. I suspect the guy who sold it to me (cheap I hasten to add)
probably couldn't make it work either. Though if he sees this I'd gladly stand corrected.
Tried both metal flags and magnets
My first pass was power the gauge via + and - then one or other wire on the transducer to G then the other to ground. As I say I've tried a few
different combinations since then and nothing even makes the needle twitch. I really need the definitive wiring diagram I suppose but the manufacturer
was not helpful
I've probably already knackered it by now anyway...
ho hum...wheres that beer ?
OFROK
stephen_gusterson
| posted on 19/2/04 at 10:51 PM |
if its a simple inductive transducer, you wont get much of a signal out of it unless it sees rapidly moving metal.
you really need some source of generating pulses that you could connect to speedo to see it it reads...
atb
steve
jonti
| posted on 19/2/04 at 11:07 PM |
As I said in my first post, I used magnets stuck to a sanding disk and, prior to that, a metal flag in the chuck of a power drill.
I suspect my propshaft and/or anything else wouldn't rotate faster than that...
It may be buggered of course but unless I'm sure it's wired correctly I'll probably never know......if no-one comes up with a
definitive wiring diagram I'll probably bin it......lifes too short.
Thanks anyway
Anybody got any other thoughts.......other than bin it
OFROK
stephen_gusterson
| posted on 19/2/04 at 11:23 PM |
nope - i meant ditch the sensor, and get some means of giving pulses to the rev counter to see if that works. You would need to use a frequency
generator / oscillator or similar
If it does work, you should be able to pick up some kinda sensor from farnell or rs components to replace the one that might be dodgy.
jonti
| posted on 20/2/04 at 08:19 AM |
Aha..I see wot yer mean....fair plan and, indeed, if I still had access to a scope I'm sure I could sort it neh bother....... and then still
find out it's buggered...
Nah..thanks Steve, but if someone KNOWS how it should be connected or has a similar one, then that would be great and I can easily prove or disprove
it. Otherwise I'll write the tenner off to experience and bin it I think.
As I said..lifes too short..I'm building a car not fixing clocks........upward and onward.
PS
Ehup Syd....the beer didn't help either (well not with this problem anyway) I'll still keep using it though..... cheers mate.
OFROK
[Edited on 20/2/04 by jonti]
OFROK
theconrodkid
| posted on 20/2/04 at 08:35 AM |
same pick up as ive got,if i remember corectly one is a live from the speedo head and the other goes to earth
who cares who wins
pass the pork pies
jonti
| posted on 20/2/04 at 09:43 AM |
Star man..cheers my friend
So the pick-up parallels off the gauge live then ?
Does it need a magnet or just a metal flag to trigger it ?
OFROK
theconrodkid
| posted on 20/2/04 at 04:28 PM |
ive got some magnetic strip from a fridge door attached to a cv joint,just play around with the numbers till you get it right
who cares who wins
pass the pork pies
jonti
| posted on 20/2/04 at 11:30 PM |
Ok cheers
I'll have another play tomorrow
OFROK
stephen_gusterson
| posted on 21/2/04 at 11:49 PM |
how can effectively wiring the two wires across the battery (as one will be gounded and one will be at guage 12v) work?
if anything, id say oen si earthed and the other goes to a signal pin, or power and a signal pin. but across power and ground - nah.
Or have I misunderstood?
atb
steve
theconrodkid
| posted on 22/2/04 at 07:29 AM |
steve,its the OUTPUT wire on speedo head,not ign live,that gives it the signal,and yes you are missunderstood
who cares who wins
pass the pork pies
bob
| posted on 22/2/04 at 09:01 AM |
Not sure if this helps but ive got a VDO electric sender with the same type of pick up,on back of speedo the plug has 8 pins and i'm using 4 of
them.
They are numbered so its as follows.
3/ = earth
4/ = ign live
7/ = sender
8/ = sender
My senders wires are the same colour and it didnt seem to make any difference which slot they went in,its obviously a feed and return and pulses at
sender.
jonti
| posted on 22/2/04 at 08:38 PM |
For Mr Gustos peace of mind...
One wire does parallel off the Live and the other does indeed go to "ground"? ... not chassis but the G tag on the clock probably
doesn't mean "ground" but "gen" for sign gen or something
Seems to work anyway
Thanks again
[Edited on 22/2/04 by jonti]
OFROK
