Motty
| posted on 16/5/04 at 08:37 PM |
Wipers not parking
I have asked this question before but am still having trouble so can anybody help me please. I have a Mini wiper motor which I have changed the cam on
so that it parks on the correct side, the problem is that it refuses to park at all. Both speeds are working and it stops but just will not park, I
have changed the microswitch but this hasn't helped. I understand that the parking side of things should be live when the wipers are switched
off but where should I get this live feed from. Any ideas please?
ady8077
| posted on 16/5/04 at 09:48 PM |
Have a look at the attatched drawing
Its off the Tiger chat group
Adrian
ady8077
| posted on 16/5/04 at 09:53 PM |
Dont think the link works
Go to http://autos.groups.yahoo.com/group/tigerracing/
And look in the files section, under wiring diagrams. Or u2u me your email
Adrian
Dusty
| posted on 16/5/04 at 11:23 PM |
The tiger diagram shows the links well but doesnt show that the column or dash switch must connect 2 and 5 on the mini wiper motor when in the
off/park position. There is a dedicated Lucas switch that does this or the standard sierra switch will do it if wired as shown. The washer wiring is
not as shown for post 87 column switches.
zetec
| posted on 17/5/04 at 07:37 AM |
Might be worth asking Premier Wiring. I fitted mine as per their loom and instructions and worked first time. Other thing to make sure is that the
gear is able to contact the switch. When I stripped mine to clean and regrease I forgot to fit a washer that holds the driven gear in place, too much
endfloat and it would not work the park switch.
Steve @ sVc
| posted on 20/5/04 at 05:28 PM |
Motty
Have you looked in the wiper section of our web pages? www.s-v-c.co.uk.
Which switch are you using?
Call me if you like @ local call charge on 08 456 581 451
Regards
Steve @ sVc
