vintagebuilder
| posted on 17/6/10 at 02:07 PM |
Speedo problem
Hi,
Got a "Greengauge" electronic speedo with 4 magnets on the propshaft. The speedo reads accurately up to 50 m.ph then the pointer
doesn't go above this.
Any advice would be welcolm.
Regards
david
| posted on 17/6/10 at 02:12 PM |
How close is the sensor to the magnets? If the gap is large the sensor will get less of a signal from the magnets and it might be that at speed (when
the magnets are moving quickly) its too quick to trigger the circuit. Worth a shot anyway
Agriv8
| posted on 17/6/10 at 02:32 PM |
What type of spedo pickup does it use ?
regards
Agriv8
| posted on 17/6/10 at 02:33 PM |
Yep, I had a similar problem and 'fine tuned' the gap down to not much at all. Working well now though.
Lars
| posted on 17/6/10 at 03:02 PM |
i moved the pick up to my cv joint when I had the problem, mine did not read above 30, but is now fine
vintagebuilder
| posted on 17/6/10 at 04:18 PM |
Speedo problem
Dear Agriv8,
I used a reed proximity switch from Farnell.
Regards
sucksqueezebangblow
| posted on 17/6/10 at 04:34 PM |
Yep, same problem with my hall effect sensor, need to move it closer to the target (bolt heads)
vintagebuilder
| posted on 18/6/10 at 06:47 PM |
Speedo problem
Hi,
Thanks for the replies.
Regards
