david
| posted on 13/7/10 at 11:33 PM |
reverse gear
i have fitted a electric reverse gear and want to use it only when the gearbox is in net. The fireblade net. operates the earth. I have power to the
net. warning light and when the net. is selected the warning light comes on. How do I get the live to come on only in net.. do i need an other relay.
hope this is clear. any circuit or help would be welcome. David
Stott
| posted on 13/7/10 at 11:56 PM |
You could have the power to the starter solenoid through a relay. Standard 30a automotive type.
The connections would be switched live to terminal 85, terminal 86 then being teed into the switched earth on your neutral light. So when the neutral
light is activated, and earths the lamp, it also earths the coil of the relay bringing it in.
Terminal 30 and 87 of the relay would then be interrupting the power to or from your reverse motor switch
[Edited on 13/7/10 by Stott]
Like this:
[Edited on 14/7/10 by Stott]
jlparsons
| posted on 14/7/10 at 12:24 AM |
I'm planning a similar idea, with a reverse select switch which can engage reverse only when the box is in neutral and the brake pedal is
pressed. The reverse motor then engages whenever the brake pedal is lifted until either the clutch is engaged, handbrake put on or the reverse switch
is pressed again, which will disengage reverse. Hence reverse movement will be entirely foot operated as "normal", with the driver free
to steer and twist to look behind without having to free a hand to press a reverse button at the same time.
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
nitram38
| posted on 14/7/10 at 06:15 AM |
Theres no need to get too complicated with brake pressed linked in etc!
On my R1 I used the neutral warning light as a relay control wire and a 3 position toggle switch off on momentary with a doomsday cover.
The first on position brings on the reversing lights. The momentary controls the starter solenoid so that as soon as I let go the car stops.
[Edited on 14/7/2010 by nitram38]
| posted on 14/7/10 at 06:45 AM |
Like this:
There's a slight error on that diagram. At present the relay is attached to the earth. You want it attached the other side of the switch. IE
between the neutral switch and the neutral light. But otherwise it's all good
40inches
| posted on 14/7/10 at 07:20 AM |
I am thinking on simular lines using a ZX9R-B clutch switch on the pedal, like the idea of using foot control
Stott
| posted on 14/7/10 at 08:07 AM |
Yeah well spotted, that's 1am, wine and drawing in paint for you!
I've altered it now so the diagram in the 2nd post in this thread is now correct,
Stott
david
| posted on 14/7/10 at 10:26 PM |
reverse gear
Tks. lads, wired it up today and it works great. david
MartinDB
| posted on 16/7/10 at 10:12 PM |
Do you have a part number or supplier for the 3-way toggle? I'm looking for one but not having any luck.
Thanks.
nitram38
| posted on 17/7/10 at 04:59 AM |
Its sold as an ignition switch. I know Demon used to sell them.
Longacre are the Manufacturers
MartinDB
| posted on 17/7/10 at 10:27 AM |
Thanks Martin, they still do them .
