shortie
| posted on 25/7/04 at 04:46 PM |
Indyblade electrics
Attached is a doc showing how I plan to wire the ignition\starter part of my indyblade loom.
Can you guys just have a look and see if there are any glaring errors?
Wondered whether I should have the fuel relay direct off a fused feed and also whether the black white wire from the CDI is going in at the right
place to the black fused ignition feed.
Any help would be much appreciated!
ta,
Rich.
Berwyn
| posted on 25/7/04 at 07:23 PM |
looks ok apart from the 2 coil wires onto the fuel relay, but that might just be down to the year of your blade. Mine only required the 1 coil feed.
24 hours in a day, 24 beers in a case. Coincidence? I think not
shortie
| posted on 25/7/04 at 07:57 PM |
probably just the way I have drawn it, single Black\White wire actually splits near the coils.
Rich.
