Ivan
| posted on 3/4/12 at 10:45 AM |
Electric connectors - only rubbish available
Been fitting my new Speedhut Rev counter and GPS Speedo but had to purchase insulated spade connectors and didn't realise what krap they
are until I got home    .
20 years ago when I wired up my Cobra the connectors extended to grip the insulation as well as the bared wire - now they only grip the bared wire so
any good tug tends to either break the wire or pull it out of the friction joint. Why did they have to change a good design - guess we have the
Chinese manufacturers to thank - and the price does not reflect the poor quality either and even worse it is all that is easily available. .
Bought a four way plug (Male and female) and when I assembled it and trial connected it I could not disconnect it without breaking it - another
brilliant piece of Chinese design I warrant.
You brits and europeans really let us down by allowing your manufacturing base to die.
By the way both work brilliantly - it's good to have finally a speedo after driving for 20 years without one. Looking forward to finishing
running in the new motor so I can test the 0 - 100 timer and the 1/4 mile timer on the speedo and the shift lights on the rev counter.
owelly
| posted on 3/4/12 at 11:25 AM |
I still buy and use good quality crimp connectors and multi-plugs. Don't blame anyone else if you buy crap!
http://www.ppcmag.co.uk
blakep82
| posted on 3/4/12 at 11:26 AM |
bare wire, crimp, drop of solder? thats what i do on the multi plug type pins, on the rare occasion i do anything with them
________________________
loggyboy
| posted on 3/4/12 at 11:27 AM |
But it was these cheap crap alternatives that led to the good quality stuff dieing off as everyone buys the cheap stuff now.
So by buying cheap, it was infact you who allowed it to die
Ivan
| posted on 3/4/12 at 11:39 AM |
I am willing to pay for quality if it were available - just can't find it - not even at the better retailers. So don't blame me for the
problem. Although I suppose if I was willing to drive 100 km or so to the other side of town and back and spend the better part of a day looking I
might find a supplier for a few pounds worth of goods - but that's hardly a reasonable choice. It's just that most stores only stock the
rubbish.
[Edited on 3/4/12 by Ivan]
dave
| posted on 3/4/12 at 12:05 PM |
try RS
SPYDER
| posted on 3/4/12 at 01:19 PM |
We buy all our electrical stuff from Vehicle Wiring Products. They sell the blade connectors of the type you require plus multi connectors etc. Look
on the website. They will post you a catalogue.
V W P linky CLICK HERE
iank
| posted on 3/4/12 at 01:23 PM |
To South Africa?
Anonymous
loggyboy
| posted on 3/4/12 at 01:31 PM |
These guys deliver to SA for £1.80
4 Way - Waterproof / Weather Proof, Sealed Electrical Connector KIT - 12V 24V DC | eBay
[Edited on 3/4/12 by loggyboy]
D Beddows
| posted on 3/4/12 at 02:30 PM |
Perhaps rather than blaming Europe you should vent your frustration at your own country for putting up with being supplied cr*p? As has been said
there's no problem buying decent connectors here!
Ivan
| posted on 3/4/12 at 02:50 PM |
You might be right there.
| posted on 3/4/12 at 03:18 PM |
Vehicle Wiring Products will probably ship to SA for you and supply some decent heatshrink insulated crimp terminals. Crimp them onto the wire
(including an insulation crimp section for strength) then heatshrink the sleeve to give a nice tight moisture proof fit.
Volvorsport
| posted on 3/4/12 at 05:14 PM |
seconded on the heatshrink terminals . i dont use anything else if i can help it.
www.dbsmotorsport.co.uk
getting dirty under a bus
SPYDER
| posted on 3/4/12 at 09:30 PM |
To South Africa?
Click on the link, then click on the EXPORT tab. Easy.
