johnny chimpo
| posted on 11/5/13 at 06:38 PM |
Anderson Connector?
Hi all, I'm looking for a quick and easy way to connect up my battery on my MNR for charging without having to remove the bonnet. What I was
thinking about was to run A lead from the battery terminals into an Anderson connector under the dash that could be easily accessible.
Are Anderson connectors suitable for this purpose and if so what rating/size of connector would I need to fit?
Also anyone able to sugget the best place to buy from?
Cheers all....
AndyW
| posted on 11/5/13 at 06:57 PM |
i used to use Anderson connectors on electric fork lift trucks and they were rated by colour. Some were rated for very high voltage and very high amps
so get the right one and they will be fine for the car. If you look at recovery vans they usually have on behind the grill or bumper
RickRick
| posted on 11/5/13 at 08:20 PM |
I've done this, but using rc car connectors, there good for easy 30 amps, put the female side on leads off the battery, and mount under the
dash, and a male end on the optimate, just plug it in every time i get in
Deans Connectors T Plugs 5 Pairs | eBay
T66
| posted on 11/5/13 at 08:29 PM |
Ive seen cars at Harewood with flush mounted Anderson plugs. Use a small battery once running and a trolley battery to start the car.
Mr C
| posted on 11/5/13 at 10:13 PM |
Its quite a common addition within the off road scene old land rovers etc. I've put an anderson connector on my v-storm and jump pack, as the
battery is difficult to get at for jump leads. I used 175amp connectors and 25mm terminals. I bought a pair of hydraulic crimpers to do the terminals.
I bought jump leads from machine mart and used the cable. I kept a pair of crocodiles and put and anderson plug on them so I could uplug them into
the jump pack and use "normally" if required. Loads on Ebay just make sure you get your shopping list sorted before you order, handles,
rubber boots etc are usually ordered separately. Make sure also you get the right size connectors for the cable you are using. It wasn't locost
at the end of the day but its so convenient espcially when my gel battery fooked up.
Girl walks into a bar and asks for a double entendre, so the barman gave her one
johnny chimpo
| posted on 11/5/13 at 10:34 PM |
Can you recommend what amp rating connector and what size of cable I should use for my r1 engined MNR?
Matt @ TDF
| posted on 11/5/13 at 10:40 PM |
We fit jump points/pit points via Andersons as standard on all our looms for the race cars we deal with.
You can quite happily get away with the smaller "grey" 120 type for basic power and starting duties and these can be flush fit or panel
fit via the mountings on the connector. The larger Red 350 type is quite useful for quick jump starts etc. especially on larger engines or high
current draw applications (e.g. when you have paddleshift compressors, electric oil pumps etc. running during starting) and you can bolt a useful
handle to the red type for easy connect/disconnect.
Cheapest place for single orders is probably RS:
Grey 120 Type: http://uk.rs-online.com/web/p/heavy-duty-power-connectors/6120065/
Red 350 Type: http://uk.rs-online.com/web/p/heavy-duty-power-connectors/6120144/
omega 24 v6
| posted on 11/5/13 at 11:43 PM |
Not trying to wee anyone off , given some of the latest posts etc.
For a better deal on these connectors try here
connectors
Matt @ TDF
| posted on 11/5/13 at 11:51 PM |
connectors
That's a 175 not a 120 so bit bulky for under dash mount. Also the ones I listed above include terminals as a bagged kit, not just the bare
terminal housing which makes life a bit easier
omega 24 v6
| posted on 12/5/13 at 12:09 AM |
We use 50 to 60 a week at work and they come with the terminals in the box. Not sure if thats just for us though. Cannot see the terminals on the site
as a separate order either so would assume they come as a complete kit.
As I said not trying to contradict anyone just get the best deal for a fellow locoster.
And as we use them at work it was easier for me to use something that I was used to working with
Mines is mounted on the pass side footwell ( in the engine bay at floor level) and doubles as a jump start/batt conditioning connection. I have a
mating section that has a set of crocodiles on the other end. It allows me to jump start my car OR for me to jump start someone elses car AND connect
to the batt conditioner ( which also has a mating section )during winter.
johnny chimpo
| posted on 15/5/13 at 10:46 PM |
Would the 50amp Anderson connectors be suitable for this or would it really need to be the 120amp minimum? it will only be used for charging the
standard 12v Yuasu battery in my r1 engined MNR.
cliftyhanger
| posted on 16/5/13 at 07:10 AM |
For charging?? you only need 10-20A, depends on what charger.....
Matt @ TDF
| posted on 16/5/13 at 11:07 PM |
As above, but if you are going to effort of fitting an Anderson you may as well make it possible to jump the car through it. It won't take a lot
of cable or a much larger connector all things considered.
If you only want to pass 10 amps or so for charging use a two way Deutsch DT connector which will support 13 amps continuously and supports 14 AWG
wire.
britishtrident
| posted on 17/5/13 at 05:57 AM |
If only using it for car to car charging it is easier just to use one of those cigar lighter socket to cigar lighter socket leads ---- I
used my Lidl one a few times and it works surprisingly well
If you are using one of the lower rated Anderson connectors wiring it through a Mega or Maxi fuse might be a good idea.
[/I]
matt_gsxr
| posted on 17/5/13 at 06:50 AM |
I have a CTEK charger which was recommended for my Odyssey battery.
This came with a very nice cable and plug (with waterproof cap) that are designed to be wired in permanently. The CTEK units can be left plugged in
permanently and are nicely made, I would go this route again.
I have used Anderson, but only for jump starts (far too meaty for this purpose and a rather crude connector IMO).
Matt
Bluemoon
| posted on 17/5/13 at 09:10 AM |
^^^ Ditto.. Not needed for normal charging as OTT on the current rating.. Mine is as BT, perfect for satnav as well..
J222jra
| posted on 17/5/13 at 09:26 AM |
Definatly just buy a ctek charger with the quick connect lead. I just keep it connected all the time in the garage to keep the battery conditioned.
It basically turns itself on when the battery gets below a certain voltage.
