i_froloshki
| posted on 25/6/13 at 05:14 PM |
Speed sender problem
Hi folks,
I have a problem connecting the sender with the speedo. I have this sender
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260802779601&clk_rvr_id=494361429041
and i have this speedo
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250761383431&clk_rvr_id=494356961511
The current setup of the sender is as follows:
I made the speedo connection as in the manual, and it is working, but it seems that i do not get any signal from the sender. I am doing the wires as
in the instructions for the sender, but i do not get any signal. I made a small mistake and connect the speedo signal cable to the tacho wire and it
works. So where is the mistake with the sender installation - 2 wires, brown - ground, blue - signal. the magnet is very strong, tried with another
one to decrease the gap - same sh-t.
Help please.
Thanks.
Yavor
i_froloshki
| posted on 26/6/13 at 09:02 PM |
Hi, so many answers, i do not know which one to use )))) No worries folks, problems solved - just used the original electronic VSS of the MT75
gearbox ( 3 wires- power, ground, signal) and calibrate the speedo (1 mile - 8500ish pulses).
Yavor
