Author: Subject: Water Temp Gauge Reads Too HOT but it's not
blockpower
posted on 26/6/14 at 05:41 PM Reply With Quote
My temp gauge reads hot even though the engine is operating within normal parameters. The engine never overheats I'm wonfdering if it is just the sensor could somebody give me some advise please?
2000cc Zetec smiths 52mm gauge.
Many thanks
big-vee-twin
posted on 26/6/14 at 05:55 PM Reply With Quote
Is it a Smiths sensor matched to the guage?
http://www.triangleltd.com
micksalt
posted on 27/6/14 at 08:53 AM Reply With Quote
Is there enough free cable in the wiring loom to dangle the temperature temperature sensor into a cup of water? I used this technique to diagnose a fault in my daily driver. With the sensor removed, but still wired up to the loom, I dipped it in cups of water of varying degrees of temperature whilst simultaneously taking a reading with a known, good electronic thermometer. Turns out that although the cold and operating temperatures were right, it had lost linearity in the warming-up region.
alfas
posted on 10/7/14 at 10:08 PM Reply With Quote
zetec ususally does not have a (free) thread where you can screw-in a typical smiths sensor.
have you upgraded your car from a x/flow or pinto to zetec?
yes? than you should have kept the "old" sensor, installing it in something like this:
you can find them at ebay
cliftyhanger
posted on 11/7/14 at 05:58 AM Reply With Quote
Many older smiths gauges run off a stabilised 10v supply and need a specific sender. 12v will cause it to overread....
alfas
posted on 11/7/14 at 08:37 AM Reply With Quote
original one
modern one:
alfas
posted on 11/7/14 at 08:38 AM Reply With Quote
if the instrument is connected direclty to power (12V) it will read too high
alfas
posted on 14/7/14 at 07:05 AM Reply With Quote
here sale´s link of those modern stabilisers:
Semiconductor Voltage Stabilizer- GT6 Spitfire Stag 250
