JC
| posted on 20/9/15 at 09:41 AM |
Zetec SE Clutch switch
Hi all,
My donor Fiesta (96 1.25 Zetec SE) had a clutch switch - a simple plunger operated by the pedal. It will be a faff to incorporate it, either as it
was or by using a hydraulic brake switch instead.
On the Haynes ECU diagram, it shows this switch as an alternate to the automatic transmission start inhibitor.
Is its function solely to prevent starting unless the clutch is depressed - in which case I will wire it permanently 'on', or does it do
other things that will cause be issues if it is bypassed?
JC
big_wasa
| posted on 20/9/15 at 01:45 PM |
Should have no connection with the starter inhibit relay.
The reading I've done suggests that it increases the rpm a little via the idle control valve when your sat at a junction ect. ie its a load
switch like the heated windows and ac.
I am always happy to be put right if some one knows different.
Just check if the switch is normally open or normally closed. I cant remember what way around it is.
If its N/o just remove the pin and if its N/c I think from memory you just add it to the earths.
Either way you don't need to add anything to the car.
[Edited on 20/9/15 by big_wasa]
JC
| posted on 20/9/15 at 09:08 PM |
Thanks - thinking back, when I had the engine running I think I had to 'make' the switch for it to start. I might just wire a toggle
switch on the dash to add to the start sequence and also double as an extra immobiliser!
monkeyarms
| posted on 21/9/15 at 11:54 AM |
HI, I have done 2 zetec SE installs and big wasa is spot on.
Just connect the wire to earth. no problems.
Same if there is power steering on the donor car, there is a presure swtich, again wire to earth.
The Ford TIS is helpful here (if you can find it)
JC
| posted on 21/9/15 at 12:25 PM |
cool, thanks
big_wasa
| posted on 21/9/15 at 12:28 PM |
I've never seen the brake or clutch needing depressing to start on a manual trans' Ford upto and including 2004 before.
