Author: Subject: Best loom???
Avoneer
posted on 24/5/05 at 10:12 PM Reply With Quote
Best loom???
Whatever loom I buy, I will need to tailor it to the following 3 requirements, so which loom is going to be best to meet my requirements?
1) Fireblade engine loom to splice in.
2) Digidash.
3) Lots of switches as I'm not using any stalks.
At the moment, Premier, Vicky Green or that expensive module from Car Builders Solution are in the running - unless anyone else has a better idea...
Pat...
DavidM
posted on 24/5/05 at 10:36 PM Reply With Quote
I'm installing a Premier loom at the moment. No problems so far despite being an electrical numpty. Have found them to be very helpful. Shouldn't be any problem with all the switches. Don't know about the Fireblade loom and digidash but I'd be willing to bet they would help you accomodate these.
Proportion is Everything
chriscook
posted on 24/5/05 at 10:54 PM Reply With Quote
I built my own, reasons here:
http://www.locostbuilders.co.uk/viewthread.php?tid=26631
Chris
[Edited on 24/5/05 by chriscook]
Avoneer
posted on 24/5/05 at 11:02 PM Reply With Quote
Don't fancy the build it yourself route.
I used a Premier loom on the Avon and found it easy, so may go this route and adapt it to suit switches instead of stalks - unless anyone comes up with another suggestion.
Pat...
Hellfire
posted on 24/5/05 at 11:36 PM Reply With Quote
You know it makes sense to DIY Pat what you scared of? If you've done it once - where's your sense of adventure
niceperson709
posted on 25/5/05 at 01:50 AM Reply With Quote
Hi pat why not use the blade loom ?
best wishes
Iain
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
Kissy
posted on 25/5/05 at 06:30 AM Reply With Quote
I used the bike loom as a base when I did mine, and built the rest to suit. It isn't rocket science. Just place all the components where you want them in the car, take your time and off you go! I used the Haynes wiring diagram as support.
It's in the spirit of Locostery after all!
Stuart Ainslie
posted on 25/5/05 at 07:11 AM Reply With Quote
I'm using an Autosparks loom...
All straight forward and no problems. Connected up to a Pinto, Sierra switchgear and an ETB Digidash
indykid
posted on 25/5/05 at 08:54 AM Reply With Quote
get yourself a sierra loom, name some dates, and i'll come and give you a hand. i found building my own loom to be one of the most beneficial and rewarding things to do.
do you know what every wire on the avon does, purely on colour and position in the car? does your loom run exactly where you want it?
go on, if you can build a chassis, a loom should be a doddle
tom
