Danozeman
| posted on 19/4/06 at 09:03 PM |
Vicki green fuse box.
Does anyone know what fuse does what in the Vicki Green fuse block?
Also where have people tapped the feed from for megajolt if any of you have a VG loom and megajolt.
Thankyou please.
[Edited on 19/4/06 by Danozeman]
Dan
BKLOCO
| posted on 20/4/06 at 04:21 AM |
Use the white and black wire that is labelled ECU on the wiring diag for the switched supply to MJ.
I can't remember what the fuses protected as I added a larger box. Its easy to find out when its installed though you just pull em and see what
stops working
Danozeman
| posted on 20/4/06 at 05:31 AM |
Thanks mate. I wasnt sure what those white wires did. I know it says to ignition system on the diagram but didnt know if they were switches or
not.
Im going to change the fuse box anyway just wondering what did what to make it easier,. Plus iv chopped the wiper and heater bits out and want to
kill the power.
Dan
