Danozeman
| posted on 26/4/06 at 04:09 PM |
Megajolt not seen on pc.
My pc running xp wont see my megajolt. It says com1 one not connected or there abouts.
Any idea's?
I have a straight through lead by the way.
Dan
BKLOCO
| posted on 26/4/06 at 04:15 PM |
baud rate?
something else using the comm port?
I love speed :-P
| posted on 26/4/06 at 04:24 PM |
Are you sure it is a stright throught lead, as i brouht one, and on the pack it said stright through and it wasnt.
Also the port might not be comm1 try all of them which are avalible
One more thing, if your using a power pack for power, try a battery, as this messed my megasquirt up
Don't Steal
The Government doesn’t like the competition
Danozeman
| posted on 26/4/06 at 04:40 PM |
My mate tested the lead its definatley a straight through. Hes an IT man but hasnt got a spare minute for a while and i want to gett the proper map
on it.
I only have one serial port and nothing was on it before.
Dan
muzchap
| posted on 26/4/06 at 04:45 PM |
Try uninstalling the port in windows are re-installing.
Also double check you have the right version of software to talk to the MegaJolt.
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Jed
| posted on 26/4/06 at 07:42 PM |
I take it that you have installed the java comm API software? As per the notes here
mark chandler
| posted on 26/4/06 at 07:58 PM |
I had to use a crossed lead to see mine !
Danozeman
| posted on 27/4/06 at 09:15 PM |
Dam thing. Iv tried all that java stuff etc and it still doesnt work. It says "unable to open port com1 Unknown serial port"
Itl connect to the unit using that hyperterminal thing so the port works.
Dan
chockymonster
| posted on 27/4/06 at 09:19 PM |
When you say it connects with hyperterminal what do you mean and how do you know it can see the unit?
Danozeman
| posted on 28/4/06 at 06:06 AM |
I followed this
and it does what it says it will.
Dan
paulf
| posted on 28/4/06 at 08:28 PM |
Most likely a java problem , did you install it from the self installing package on the CD? I find this usually works straight away but did recently
have a problem and found that it was loading the wrong version of Java, as i had two versions installed somehow, check the properties by right click
on megajolt tune , it should be something like this "C:\Program Files\MJLJ Tune\mjljTune-2.0.3.jar"
Paul.
Danozeman
| posted on 28/4/06 at 10:19 PM |
Sorted. Just uninstalled all the java i had on my pc and let megatune install the one it wanted and away it went.
Think i had conflicting java's...
Dan
