Author: Subject: megajolt run time display
tim windmill
posted on 16/5/06 at 06:38 PM Reply With Quote
have megajolt installed now on a 2.0l pinto with zx9 carbs and i am trying to get to grips with the megajolt. i cannot import a map as i keep getting a configuration error. have tried reinstalling java etc but still no joy. but have managed to load data onto megajolt manually. engine seems to run ok but i am unsure what is supposed to happen when you have the megajolt on "run time display" can someone enlighten me please
viatron
posted on 16/5/06 at 07:21 PM Reply With Quote
As it says "runtime" with the engine running as you increase revs you should see the active cell in the map become highlighted.
Mac
tim windmill
posted on 16/5/06 at 07:33 PM Reply With Quote
thought that was the case but nothing is highlighted on my display so i will go back and re check wiring. thanks for the info
Danozeman
posted on 16/5/06 at 08:51 PM Reply With Quote
Have u got the correct straight through cable to connect the Megajolt to your pc??
I had trouble gettting mine to work. I had to unistall every little bit of java on my pc and let megatune install the one it wanted. Works perfect now.
Dan
