RazMan
| posted on 24/5/06 at 02:46 PM |
Current draw of 'boot poppers'?
I'm going to fit a couple of
these as remote door
lock actuators in my middy (saves mechanical linkages etc) and wondered if anyone knows what current they draw to get a reliable action. I want to
have the doors powered by a separate (small) battery which will be independent from the main battery and need to know how big it need to be.
Raz
k33ts
| posted on 24/5/06 at 05:20 PM |
there quite high dont know exact figures but i know they pop a 10amp fuse
tukcustoms.com
RazMan
| posted on 24/5/06 at 09:18 PM |
10A EACH ?? !!
Looks like I might have to rethink
Raz
ady8077
| posted on 24/5/06 at 09:54 PM |
Hi
Its probably the surge that blows a fuse, why do you want them off a secondary battery?
Adrian
RazMan
| posted on 24/5/06 at 10:03 PM |
I intend to use the battery cutoff switch when parked but if I close the doors with the power off I won't be able to get in the car.
I thought a secondary battery (the type used as backups in alarms) could be linked to the main one using a diode to stop it draining when the main one
is switched off. That way I can always get in the car .............. which is nice
If they take 10A I might have to wire them direct to the main battery instead. Only drawback will be the flat battery scenario
Raz
k33ts
| posted on 24/5/06 at 10:27 PM |
i take it your havin no door handles or locks and that when you say parked you mean left in the garage as the solenoid wont drain it.
the best way to get over the flat battery is to hide a socket maybe a cigarette type(hella do some nice waterproof ones) under or somewhere accesable
but no visable.
itll be handy for say trickle charging when your not using motor and especially so if you get a flat battery.
hella blugs and sockets
http://www.4x4cb.com/public/shop_preview/products2.cfm?CatID=518
[Edited on 24/5/06 by k33ts]
tukcustoms.com
greggors84
| posted on 24/5/06 at 11:00 PM |
You could run them off the same battery, and have the battery cut off switch isolating the rest of the electrics. Still would have a problem with the
flat battery scenario though if you left the lights on etc.
Chris
The Magnificent 7!
chockymonster
| posted on 24/5/06 at 11:09 PM |
A friend had a similar setup, to get around the flat battery problem he had a a pp9 battery connector connected directly to the driver's door
and hidden securely. A pp9 had enough juice to fire the door popper to let him in to the car.
RazMan
| posted on 25/5/06 at 06:55 AM |
Aha so it looks as though the 10A figure was a little ott to say the least - if a pp9 can operate a solenoid it can only be a few mA.
I think I will do as suggested and have a 12V socket discretely hidden somewhere for emergencies (and trickle charging) and have the solenoids
bypassing the cutoff switch.
Thanks guys
[Edited on 25-5-06 by RazMan]
Raz
ady8077
| posted on 25/5/06 at 10:02 PM |
Is it ok to have auto doors for SVA?
Adrian
stevebubs
| posted on 25/5/06 at 10:45 PM |
TVR Chimaeras don't had door handles just buttons...
Crazy Jay
| posted on 25/5/06 at 11:59 PM |
They wont pass mot normally. I know a guy who had to have a spare set of doors for his mot coz he had de-handled his car
RazMan
| posted on 26/5/06 at 07:05 AM |
Hmm ... interesting - so how do Chimaeras pass mot I wonder?
[Edited on 26-5-06 by RazMan]
Raz
ady8077
| posted on 26/5/06 at 04:20 PM |
Hi
I sva'd my stylus with no outer door handles, just internal ones, but i didn't have locks. SVA man never mentioned it
My stylus and TVR's are soft tops though, maybe that helps?
Adrian
