richyo
| posted on 15/8/06 at 12:42 PM |
Alternator Wires - Where to ?
As the heading says. I'm using a x-flow with standard alternator. Where can I put the red wires to ? Do they have to go directly to the battery
positivice or can I take them there via the starter or via the solenoid ?
It an inertia starter so solenoid is remote.
TIA
Richyo
RazMan
| posted on 15/8/06 at 05:06 PM |
Depends on the make of your alternator but the main charging wire can go to the battery via the starter solenoid. You will probably have two more
connections, IG & L which go to a switched live and your panel lamp.
[Edited on 15-8-06 by RazMan]
Raz
k33ts
| posted on 15/8/06 at 08:02 PM |
main charge wire needs togo to battery
tukcustoms.com
MikeR
| posted on 15/8/06 at 08:11 PM |
according to the premier wiring loom, it can go via the starter solonoid feed (ie not the bit that only goes live when the starter is turning but the
other bit to the solonoid)
k33ts
| posted on 15/8/06 at 08:14 PM |
in other words straight to the battery to save on confusion
tukcustoms.com
MikeR
| posted on 15/8/06 at 08:21 PM |
yeah ok - fair point, but i was trying to say, it doesn't have to be one physical wire, it could join another large wire going to the battery.
richyo
| posted on 16/8/06 at 06:56 AM |
Thanks all
I'll just take straight to battery.
