Author: Subject: Vicki Green ignition wires
Steve Lovelock
posted on 28/8/06 at 08:11 AM Reply With Quote
Thanks for the pdf file, very handy.
Does anybody know what the two white ignition wires do on the loom? I built a pinto based 2B and used the wiring loom very successfully so I have bought a second one to use on a Luego. I am going to use a Megasquirt N Spark ignition and need to connect it to the loom at various points so need to have a better understanding of what those two wires do. Any ideas?
bug1
posted on 28/8/06 at 09:23 AM Reply With Quote
Hi Just wired mine in I also couldn't figger it out as they didn't seem to power up when loom was connected so I wired my system in and didn't bother using them it was easier to do it that way but I am using the standard v6 engine loom and ecu you may find you also have to put in a bigger fuse box .
Danozeman
posted on 28/8/06 at 10:39 AM Reply With Quote
One of the 2 wires is ign fed. Not sure what the other one does.. I have my megajolt running from the ign fed one.
Dan
flange nut
posted on 29/8/06 at 12:26 PM Reply With Quote
If my memory is correct the white/black wire is the rev-counter connection.
Geoff
