Author: Subject: Sierra Switches.
posted on 27/1/07 at 08:30 PM Reply With Quote
Sierra Switches.
I'm stripping the wiring harness off my Sierra to make a harness for my new kit.
I want to use only the indicator stalk on the column and put a switch on the dash for the lights. I'm not using wipers so they have gone.
The lights have 3 relays, one to switch them on and then one for dip headlight and another for the high beam. They also control fog lights so I think thats why there's 3 of them.
With the low beam fuses being 7.5 amp do I really need the relay if I use a switch on the dash. I know the original Sierra switches are rubbish but my MK2 Escort didn't have any relays!
Ideally I intend to keep the relay for high beam but not for low beam. Will that be OK? Considering i don't intend going out much in the dark!!
Any advise??
RazMan
posted on 27/1/07 at 08:35 PM Reply With Quote
As long as your dash switch is rated at 15A or above you shouldn't have any problems. Personally I would still use a relay though
Raz
jollygreengiant
posted on 28/1/07 at 11:18 AM Reply With Quote
If you are still using the Sierra collumn switch for Dip/Main beam & flash, then you WILL still need to use relays, because that switch is NOT built to take the high current loads from direct switching.
If you are after using a single switch on the dash for you main light control, then have you thought of using the rotary Granada item, and yes you would still need relays with that.
