COREdevelopments
| posted on 7/8/07 at 11:50 AM |
koso revcounter
hi all, i have the koso rx1n clcoks, i have wired it up. but have not done the revcounter yet, has anyone used the edis or megajolt output? also will
it work if i connect it upto the ford type coilpack? as in the wiring diagram for the koso clocks it sugests that it needs to be a positive feed. is
this right?
any help would be appreciated.
thanks
rob
zxrlocost
| posted on 7/8/07 at 12:21 PM |
hi try wrapping the wire round number 1 spark lead from memory try that first
zxrlocost
COREdevelopments
| posted on 7/8/07 at 02:40 PM |
ye was gonna use that as last resort as i would like it connected properly to the megajolt or edis or coil.
rusty
| posted on 7/8/07 at 07:09 PM |
if it needs a +ve signal you could show it a +ve signal via a resistor and then the _ve to the coild pack would override this so you would in affect
have a switched +ve signal.
