HAL 1
| posted on 30/9/07 at 03:42 PM |
electronic ignition
Can anyone tell me what the green/yellow wire does on the hall effect distributor ?
1985 2ltr pinto engine
Dusty
| posted on 30/9/07 at 06:47 PM |
Gn/Y is the output.
Gn is earth.
R/Bk is pos, ? 5v.
HAL 1
| posted on 30/9/07 at 08:28 PM |
The reason i asked was that i want to get rid of the ECU now as there's not much going through it so i was wondering if the dizzy could be wired
directly and where the wiring would need to go.
5 v, how would i sort that out ?
Thanks Dusty
Dusty
| posted on 1/10/07 at 12:30 AM |
Can't help there. I would suggest changing dizzy and amplifier to the inductive set-up which is fairly easily available from the scrappy. You
can fiddle with the advance curve by changing bob weight springs and wiring is easy.
DarrenW
| posted on 1/10/07 at 08:47 AM |
The way i understand it is that you must use the ECU with the hall effect ignition system. I think it takes the crank signal and translates this into
an particular advance and sends correct signal to coil / dizzy.
It is due to the complications of the hall effect system that most people use the inductive system if they want OE electronic ignition. Thats not to
say you wont get the hall effect to work - just that you may find help and advice a little thin on the ground.
HAL 1
| posted on 1/10/07 at 08:02 PM |
Thanks for all the help guys, I've got a spare dizzy that uses points etc so i'll get the engine set up properly with that and maybe get
an aftermarket kit later
cheers
