Adam
| posted on 12/3/08 at 01:09 PM |
battery cut off / Koso memory
Hello.
I need to fix a second security device for the SVA, i have a steering lock already. I was just wondering if i fitted a battery cut off switch would
my koso loose all it's settings once the battery is disconnect????
Adam
Pdlewis
| posted on 12/3/08 at 01:15 PM |
My Kosos worked fine with no power feed. I set it up then took it off for 3 weeks and it remembered all the settings
Mr Whippy
| posted on 12/3/08 at 01:21 PM |
use can usually use a thin wire from the battery to keep radios alive etc, so long as its not wired to the starter and is obviously low amps, 3amp
wire should do, with a fuse.
Schrodinger
| posted on 12/3/08 at 01:31 PM |
Isn't the ignition switch and the steering lock all you need?
Keith
Aviemore
pewe
| posted on 12/3/08 at 01:56 PM |
Ignition switch and steering lock are sufficient.
If fitting a battery cut-out IIRC you still need to be able to operate the sidelights or similar even when the battery switch is disconnected as
parking lights. Also you may want to be able to operate the hazards when it's disconnected.
Cheers, Pewe
britishtrident
| posted on 12/3/08 at 01:57 PM |
Put a 500 ohm resistors across the terminals of the master switch.
Adam
| posted on 12/3/08 at 02:14 PM |
thanks for the reply guys. So am i right in thinking i don't need one. I'm using the original sierra ignition and steering lock?
Adam
tim windmill
| posted on 12/3/08 at 03:03 PM |
Adam steering lock and ignition will pass sva no problem
tim windmill
| posted on 12/3/08 at 03:04 PM |
can confirm disconnecting KOSO still keeps memory
Adam
| posted on 12/3/08 at 03:16 PM |
Cheers Tim
Adam
