lsdweb
| posted on 6/4/08 at 08:33 PM |
90 degree 9 pin D Sub Connector / lead
Hi All
I need a 90 degree 9 pin D Sub Connector (socket) / lead.
My datalogger (Race Technology) has a front mounted RS232 port and the straight connector comes out too far and fouls the steering wheel!
Now, I have several options -
Extend the steering column - easy but will move the steering wheel too close.
Move the datalogger - no chance - it won't fit anywhere else - seriously!
Change the data logger for the latest version with the rear com port - cost at least £300 to change!
Make a small extension lead with a 90 degree socket, but I can't find one anywhere! The RS site is down so that's a pain!
Any thoughts guys?
Wyn
| posted on 6/4/08 at 08:42 PM |
I have not come across a cable with a 90 degree socket but all is not lost.
you can buy 90 sockets that mount on pcb and you would need to solter wires on as well as insulated them and there is aslo a ribbon cable variey -
this is more compact. it is not screened but should be ok for you purposes for a short run.
seems they are called IDC connectors.
whilst I wait for google to provide more info, he is a picture of sid.
| posted on 6/4/08 at 08:49 PM |
look like this:
and are avaialble in 9-way but t his is only piccy I can findright now
the_fbi
| posted on 6/4/08 at 08:58 PM |
Or piggy back a 2nd 9way D type somewhere on the case which is better for you.
Presuming its the comms rather than the GPS socket which you need to remount, then you only need to solder 3 wires onto the normal PCB mount socket
inside the case.
Or, get a RS232 to Bluetooth adaptor and stick that inside the case, then you're wire free
RichardK
| posted on 6/4/08 at 09:02 PM |
I think I've got a few left over from when I build my megajolt will have a look in a mo!
I'll get a picy posted!
OK here we are:
Not sure how much they were, £2 posted seem fair for one?
Regards
Rich
[Edited on 6/4/08 by RichardK]
Gallery updated 11/01/2011
lsdweb
| posted on 9/4/08 at 02:21 PM |
Thanks guys
I found an almost right angled connector (I went to our communications workshop) but this still gives me problems. I really don't want to open
the case so I'll try the IDC option.
RichardK - if you have a spare or two, I'd be happy to pay the £2!
Regards
Wyn
RichardK
| posted on 12/4/08 at 10:08 PM |
u2u sent m8
stevebubs
| posted on 13/4/08 at 08:43 PM |
Google for "d sub side entry 9" came up with this
