whitestu
| posted on 14/5/08 at 12:34 PM |
Acewell Magnet
I got my Acewell yesterday - thanks Russbost.
Does anyone have tips or pics of how and where you have installed the magnet and sensor.
Stu
russbost
| posted on 14/5/08 at 12:44 PM |
I would recommend installing on a driveshaft or c/v (obviously not possible with live axle!) if you can. If installing on the prop you need to divide
your wheel rotation speed by the diff ratio to set speedo correctly - best way to get accurate tyre diameter is to mark the tyre & rollthe car
thro' one full rotation, measure distance travelled. Another advantage of installing on driveshaftis that as rotational speeds are lower the
magnet is more likely to stay put!
HTH
whitestu
| posted on 14/5/08 at 12:57 PM |
Thanks Russ
I'll have a look at the driveshaft as the 1st option.
Presumably the best way to fit it is to drill and tap a hole for the magnet to go in?
Once it's installed I'll check the speedo accuracy against my satnav
Stu
UncleFista
| posted on 14/5/08 at 01:16 PM |
I cut the threaded bit off the magnet, then araldited it to the wheel rim
Tony Bond / UncleFista
| posted on 14/5/08 at 02:49 PM |
Stuck mine on top of the UJ next to the engine on the propshaft with araldite after hacksawing the thread off. Rolled the car forward one revolution
of the back wheel and divided that by diff ratio (3.62) and it reads 2mph over Sorted.
[Edited on 14/5/08 by coozer]
Jonte
| posted on 14/5/08 at 07:29 PM |
mine is on the prop. but I haven´t started the car yet so I don´t know how accurate it is
Click it
