tks
| posted on 24/5/08 at 03:57 PM |
FOG lights together with which lights???
The fogs cant burn on them selves its obgliatory to join them with some other lights...
Which lights is it??
is it
a) together with the POS lights, only if they burn the fog can burn
b) together with the main/dipped beam, only if they burn the fog can burn
Regards,
Tks
[Edited on 24/5/08 by tks]
The above comments are always meant to be from the above persons perspective.
RazMan
| posted on 24/5/08 at 04:00 PM |
I would have them switched on with the head lights (via a suitable switch of course) - that way you can leave the side lights on for parking.
Raz
| posted on 24/5/08 at 04:15 PM |
The rule used to be that they only come on with dipped beam but the manufacturers don't apply that any more but with the head lights makes
sense. They have to have a tell tale light to show they are on.
[Edited on 24/5/08 by Peteff]
tks
| posted on 24/5/08 at 06:26 PM |
its an SVA requirement to have them switch on only with some lights???
they cant work if the normal lights aren't on...
so what is the rule for SVA?
Tks
clairetoo
| posted on 24/5/08 at 08:44 PM |
I`m not sure what the SVA requirements are these days , but when I did mine I wired the fog light through a relay so that it would only come on when
the main headlights are on , and goes out when the lights are off even if you forget to switch it off .
Its cuz I is blond , innit
Claire xx
Will weld for food......
tks
| posted on 24/5/08 at 08:48 PM |
okey its clear..
main lights then..
tks
adithorp
| posted on 24/5/08 at 08:49 PM |
There isn't an SVA requirement that they have to be on with other lights. It used to be standard practice that they only operated with dipped
lights (maybe a legal requirement but not in SVA book). Now many cars are wired to work on side lights (position lights).
Mine are wired to dipped headlights.
adrian
