Chris Leonard
| posted on 3/12/03 at 05:15 PM |
Cooling fan wiring
Hi all,
should the cooling fan be wired into the constant live or the switched live circuit?
Cheers Chris
theconrodkid
| posted on 3/12/03 at 05:26 PM |
leave it permanant live through a relay of course,helps them cool down after a run
who cares who wins
pass the pork pies
RoadkillUK
| posted on 3/12/03 at 07:01 PM |
I've got mine permanent live but not relayed, is this necessarily a bad thing?
Not on't road yet mind.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
stephen_gusterson
| posted on 3/12/03 at 07:12 PM |
mine is permanent live, no temp switch, just runs all the time. you only need a relay if your temp sensor is wimpy.
atb
steve
theconrodkid
| posted on 3/12/03 at 07:27 PM |
as the motor takes a fair bit of current and thermoswitches are not bullet proof might as well put a relay in the circuit,costs nowt anyway and could
save your engine
who cares who wins
pass the pork pies
Stu16v
| posted on 3/12/03 at 09:13 PM |
...and makes it easier to wire an 'override' switch into the sysetm if so desired too.
brianm
| posted on 4/12/03 at 12:06 AM |
steve
This means it would still be running when parked up.You must have one very heavy duty battery on your car!
Jimbo
| posted on 5/12/03 at 05:27 PM |
fan wiring
have a look http://nw.rhocar.org.uk/fan%20wiring.htm
Ben_Copeland
| posted on 6/12/03 at 09:51 AM |
The above link suggests it only runs with ignition on. Means you cant walk away from your car when it's hot and the fan should be on. But
i'd be very worried if my car stalled at traffic lights anyway. Plus if the fan was drawing too much current that you couldn't start the
car! Potentially very dangerous.
So i'm with Conrod with this one, but just make sure your car is up to starting when the fan is on!
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
