eccsmk
| posted on 25/6/08 at 04:18 PM |
single phase motors
ive borrowed a cement mixer with the wrong motor on it
its turning the wrong way is there any way to get the motor to spin in the opposite direction??
thanks folks
tks
| posted on 25/6/08 at 04:34 PM |
single phase..???
mhhh....
normally a single phase engine only uses 2 windings and a third which is only enabled on startup...
the 2nd winding uses an capacitor...tu generate an offset on the normal wave shape..
google is your friend i would say...
Tks
The above comments are always meant to be from the above persons perspective.
Wadders
| posted on 25/6/08 at 04:38 PM |
As you apply power, give it a helping hand in the right direction.
Alternatively try plugging it in to a neighbours supply. My old next door neighbour had a wood lathe that ran in opposite directions when plugged into
his/my supply. weird but true.
Al.
thanks folks
eccsmk
| posted on 25/6/08 at 04:42 PM |
thank you
found a couple of decent articles on the subject
eccsmk
| posted on 25/6/08 at 04:56 PM |
Al.
thanks folks
wierdly the owner says it works for him
but i doesnt work for my nieghbours
r1_pete
| posted on 25/6/08 at 05:00 PM |
If you take the cover off the motor, where the wire goes in, there is usually a connections diagram to wire it for CW or CCW rotation.
eccsmk
| posted on 25/6/08 at 07:16 PM |
i thank you kindly
