A1
| posted on 23/10/08 at 04:29 PM |
r1 clocks
the plug into the back of my clocks is broken, any idea where to get a replacement? i went to yamaha but they said its 78 quid, with tonnes to be
stripped off...
also, the clocks read in km/h, is this okay for sva? if not where can you get converters?
cheers!
Johneturbo
| posted on 23/10/08 at 04:41 PM |
They will need to read in MPH.
if your going to use a speedohealer to get them to read at the right speed i think it can also convert kph to mph
have a look here http://www.speedohealer.com/eng/adjust.htm
[Edited on 23/10/08 by Johneturbo]
Flamez
| posted on 23/10/08 at 04:53 PM |
I bought a bike guage with no rear plug. I remedied this by buying a second loom on ebay for £20.
http://cgi.ebay.co.uk/Yamaha-R1-98-99-headlight-clocks-wiring-sub-loom-4XV_W0QQitemZ170272729625QQcmdZViewItem?hash=item170272729625&_trkparm
s=72%3A1301%7C39%3A2%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
With kawasaki the plugs are common to zx10r and zx6r
i would imagine r6 plugs are the same, ask the question someone will know.
adithorp
| posted on 23/10/08 at 06:52 PM |
I got a speedo loom from Malc at Yorkshire engines.
If you press and hold the set button it'll switch from MPH/KPH.
adrian
http://jpsc.org.uk/forum/
gabbes
| posted on 23/10/08 at 08:08 PM |
I think you can change beetwen km/h and miles in the same clock.
Check the servicemanual for the bike. I have a 2003 model and I am pretty sure of that.
A1
| posted on 24/10/08 at 12:27 AM |
yea, if you hold both buttons down it changes it, although this doesnt work for european clocks, there were lots imported back in the day, and i ended
up with one of them...
