prawnabie
| posted on 26/10/08 at 01:29 PM |
Relay wiring
Hi.
I am using a 30 amp relay to switch something that demands about 25 amps current MAX.
I have wired many relays before, but am struggling with this one!
I am using 30amp cable to feed the relay and the same cable from the relay to the device. do i need the same gauge cable to earth the relay or does it
just use a nomimal value to operate the switching side.
Shaun
| posted on 26/10/08 at 01:36 PM |
Its only the two wires that need to be heavy cable, the other two just need to be heavy enough to operate the relay.
prawnabie
| posted on 26/10/08 at 01:47 PM |
thanks mate
Mark G
| posted on 26/10/08 at 06:56 PM |
You'll need a good cable from the component to earth though.
