spud u like
posted on 22/12/08 at 12:13 PM |
fuel gauge
how can i test a fuel gauge when it is not in the car and also the fuel tank sender when it is not wired up many thanks
jabbahutt
| posted on 22/12/08 at 12:29 PM |
To test the sender draw two lines on a piece of card equal to the depth of the tank and place the sender on the top line as if fitted to the tank
Temp wire up the sender and gauge to a suitable supply and with the arm of the sender on the bottom line depicting the bottom of the tank check the
gauge read empty then move the arm up towards the top line and check that the gauge moves to full.
Take care with the length of the sender arm that it won't foul any baffles etc inside the tank.
Nigel
Mr Whippy
| posted on 22/12/08 at 12:52 PM |
Connect one wire from the sender it to a car battery (24v’s even better) and the other wire to a 'friends' mouth, when he screams then the
sender is working and that was the full side
jabbahutt
| posted on 22/12/08 at 01:40 PM |
Mr Whippy I'm suprised you didn't have some humourous observation about me dishing out advice on electrical matters
Mr Whippy
| posted on 22/12/08 at 03:05 PM |
well considering how many questions you've asked in the past you should be an expert by now...
