Author: Subject: Odessey PC545 battery, is it man enough for a pinto install?
carpmart
posted on 11/1/09 at 01:10 PM Reply With Quote
Hi Chaps
As per the question really, will this battery be man enough to start my pinto powered fury? Anyone got one on their pinto engine install?
I run quite a low compression engine as its turbo charged and a standard pinto starter. I've got the battery 'in stock' so its this or the standard car battery which I have on there! I need to change the connectors else I would just try it!
What's the consensus, standard or the Odessey?
Thanks!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
iiyama
posted on 11/1/09 at 01:56 PM Reply With Quote
495 cranking amps for 10 secs. How much power do you need????
If its broke, fix it. If it aint broke, take it apart and find out how it works!
carpmart
posted on 11/1/09 at 02:01 PM Reply With Quote
Yep thanks iiyama, I'm aware of the figures, just wanted real world experience with this small a battery. Have you used one yourself in a CEC application? Will my alternator be too big for it as well?
'94 MX5 MK1, 1.8
Worzey
posted on 11/1/09 at 02:49 PM Reply With Quote
I'm using one in a 20v 4AGE without any problems.
Caterham R400
procomp
posted on 11/1/09 at 03:26 PM Reply With Quote
Hi
Personally i only ever use the Odyssey PC625 these days. This has worked well with quite a bit of abuse thrown at it. Ie starting and stopping of the race engines which can sometimes be a PITA to start when on 40's etc. Would not go back to using the red top type ones again they are too fragile compared to the Odyssey ones.
Cheers Matt
iiyama
posted on 11/1/09 at 03:37 PM Reply With Quote
Battery is rated @ 14ah which most car batteries are, so your altenator will be fine. Whats the cranking amps of the OEM battery? Will be a lot less then the odessey I bet.
Regarding using one, yes I have one in my car although its turning a Busa motor. Could probably have gone down a size for my uses.
graememk
posted on 11/1/09 at 04:23 PM Reply With Quote
545 starts my nissan powered cec indy, not a had a prob all year with it
carpmart
posted on 11/1/09 at 04:52 PM Reply With Quote
Thanks for the replies chaps! It seems as though it will be fine so I will stick it in the car!
'94 MX5 MK1, 1.8
Roman
posted on 12/1/09 at 03:53 PM Reply With Quote
Where's the cheapest place for these?
Roman
posted on 26/1/09 at 03:56 PM Reply With Quote
Anyone?
