Author: Subject: Dash wiring?
matt.c
posted on 14/1/09 at 09:20 PM Reply With Quote
Dash wiring?
Right first off, sorry but im a complete idiot when it comes to wiring so here goes.
I am using the sierra switch gear for the high/low beam and the hazards(left stalk) and am using the key for the ignition/steering lock.
I want to remove all these and mount switches on the dashboard.
1. starter button and switch for the ignition
2. hazard switch
3. headlight high/low beam switch
How do i wire these up from the standard stuff?
austin man
posted on 14/1/09 at 11:12 PM Reply With Quote
are u planning on removing the ignition barrel if so you will create a problem for the SVA as you will not have a steering lock ? you need a means of giving an ignition live via the fuse board so would need some form of ignition which also acts as another security measure..
flak monkey
posted on 15/1/09 at 07:47 AM Reply With Quote
Matt, you should have said.
Let me know when you want it doing and I'll pop over and give you a hand.
Sera
http://www.motosera.com
nitram38
posted on 15/1/09 at 08:41 AM Reply With Quote
A steering lock is not required only two forms of security. This can be two means of electrical isolation such as an fia switch and an immobiliser.
matt.c
posted on 15/1/09 at 09:13 PM Reply With Quote
Was giving you some time to do your car instead of mine for once lol!! Still trying to decide if to remove the stalks etc or not.
