Author: Subject: switches 2 position, 3 pole
RK
posted on 26/1/09 at 02:08 PM Reply With Quote
My rocker switches for hazards, fan etc have 3 poles on the back. Why 3 and not 2? Should I run the power to them in series?
posted on 26/1/09 at 02:14 PM Reply With Quote
is this not the same question?
RK
posted on 26/1/09 at 05:50 PM Reply With Quote
Hey easy. I turn 50 in a couple of weeks. Thank you for everything . Sorry
flibble
posted on 26/1/09 at 08:54 PM Reply With Quote
3 pole switches are generally (be aware i suck at electrics!)
12v power to the common (middle?) pole.
This is then fed to pole 2 when the switch is in the off position (not every switch need to be turned on for it to be powering something) OR fed to pole 3 when it's switched on, like you'd expect from a switch.
something l;ike that anyway
