INDY BIRD
| posted on 26/1/09 at 07:15 PM |
Blackbird/fireblade regulator
Hi had problems with my blackbird regulator and managed to get hold of a fireblade one to try,
question is are they compatible to use between the 2 bikes does anyone know before i try,???????
The pins look the same but not sure if they wire up the same any ideas welcome
thanks all again
mark chandler
| posted on 26/1/09 at 08:55 PM |
Three yellows, red and black its just bike standard.
Fireblade ones are particularly weak though so make sure you only have a little battery and its in the airflow or it will quickly overheat and die!
INDY BIRD
| posted on 26/1/09 at 08:57 PM |
Blackbird is 3 yellow wires 1 red/white and a green,
red/white live green earth,
are they as bad as the blackbird ones or better both have bad histories for it,
thanks for the reply
pif
| posted on 26/1/09 at 10:11 PM |
got mine from cheshire motorcycle slavage, saw him take it off another honda. it had no fairings on it and was no more than a 250. salvage man said
all same part if appearance is same. been on mine now for 2 years no probs.
hth
pif
INDY BIRD
| posted on 29/1/09 at 09:38 AM |
Thanks all for replies,
sussed it now working
was a combination of a bad earth and replaced the regulator with a fireblade one with fins,
also moved its location onto a 8"x8" piece of ali to help disipate the heat from it,
it should also get some air over it once on the move,
may get a small fan to keep it cool if a known problem didnt realise how hot they got until i picked it up after running for about 3mins
thanks again
now ready for sva
