Author: Subject: zx14 wiring help please?
GBaggott
posted on 14/4/09 at 07:52 PM Reply With Quote
I am having some difficulty getting the zx14 engine to start. Ill let you know what Ive tried and any suggestions would help please.
Neutral (earthed - and open)
Side stand switch (earthed and open)
Stop switch (made and un made)
Up unit (is up, and various other positions)
Immobiliser key unit is being used.
All loom plugs are connected.
Things it could be:
The kawasaki dash isn't plugged in?
I have a lamda sensor in the exhaust but no corresponding plug anywhere on the wiring loom?
Perhaps some wires to the original dash need shorting/12v/earthing?
Any suggestions would help especially if you have had the same issue
Thanks in advance Gareth
minitici
posted on 14/4/09 at 08:23 PM Reply With Quote
Are you using the original key switch?
If not you will need to add a 100 Ohm resistor into the grey wire to the ECU.
Luckily the ZX14 I wired had a USA spec ECU with no immobiliser.
If you are not running the clocks you only need to supply the speed sensor with +12volts (pink wire) - but this would not prevent the engine from starting (just gives a low rev limit).
Does anything happen when you switch on?
Fuel pump priming, secondary butterflies actuating?
GBaggott
posted on 14/4/09 at 08:49 PM Reply With Quote
We are using the original key unit.
Nothing happens when we turn the ignition on. We would expect something like the butterflys to move and the pump to whir but nothing happens.
Its like something isn't satisfied in the ecu or the immobiliser isn't switching off?
minitici
posted on 14/4/09 at 09:29 PM Reply With Quote
Immobiliser system looks like a nightmare!
You need this:
US e-Bay
GBaggott
posted on 15/4/09 at 07:31 AM Reply With Quote
Yeah the immobiliser system does look like a nightmare and i have no wiring diagram for it!
Hopefully malc from yorkshire engines can help, if not a new loom as suggested will be the last resort.
Cheers for you help Gareth
minitici
posted on 15/4/09 at 08:04 AM Reply With Quote
Hi Gareth,
I've put zx14 (2006) wiring diagrams onto my website
ZX14R Wiring
If you need any other sections of the manual e mail me.
Doug.
